K
Klaus Kragelund
Hi
For an application I need to protect the electronics of an RS485
interface from surges (8/20us 1kV pulse)
The normal way be to use a transzorb, in a SMA housing or even a SOT23
device.
That is not possible since we have to be able to withstand up to 30V
DC on the bus also (that is handled by a special RS485 IC)
The problem is that the selected breakdown voltage of the transzorb
therefore is high (>30V) and a lot of energy is dissipated into the
transzorb
In another product I have used a diode from the affected node to a
ceramic capacitor with a bleeder resistor in parallel to clamp the
energy and dissipate the energy into the bleeder and that worked fine.
The diode sees very little energy and the capacitor is just charged
during the pulse
I never saw any problems doing that, but I would like to know if
anyone here has tried the same and has any inputs into failure cases
or even a better way to clamp the pulse?
One "feature" of the diode-capacitor clamp is that closely spaced
pulses will eventually destroy the capacitor, but anyhow closely
spaced pulses in a tranzorb will also destroy that one....
Klaus
device.
transzorb
during the pulse
Klaus
