W
w_tom
Its w_'s tower antenna fetish. If you plan on erecting a 280 foot
lightning rod (aka. tower antenna)in your yard and connecting it to
equipment in your house this may be relevant.
Bud is reposting the same 'attack dog' myth again. The same
response is one he cannot deny. But he will post this same antenna
myth again and again.
Incoming utility wires are equivalent to an antenna. A lightning
strike to AC electric wires down the street is a direct strike to
household appliances. Those wires act just like a 280 foot antenna.
Solution to avoid damage is also same.
Does not matter if the structure is a 280 foot tower, your AC
electric wires, a church steeple, or even your chimney. Same solution
in every case is earth ground.
What was learned in routine strikes to radio towers is then applied
to homes where lightning strikes are less frequent. What Ben Franklin
demonstrated in 1752 is the same principle behind effective 'whole
house' protectors. Plug-in protectors without earthing will somehow
stop or absorb what three miles of sky could not? That is what Bud
claims.
Destructive surges seek earth ground. A 280 foot tower does not
use plug-in protectors for the same reason they are not effective
inside homes. The effective protector - inside a radio station,
inside a telco switching center, inside the 911 emergency response
center, inside military facilities - in each case the effective
protector makes that short connection to earth. A direct strike not
earthed will then use other less conductive and more destructive paths
such as a wooden church steeple and/or household appliances.
One effective 'whole house' protector costs about $1 per protected
appliance. Since Bud's equivalent solution is about $2000 or $3000
for plug-in protectors (that have no earth ground). Which is money
better spent? The proven solution where lightning strikes 280 foot
towers is also the reliable and less expensive solution.
One 'whole house' protector properly earthed means a surge will not
overwhelm protection already inside appliances. Bud's own citation
Page 42 Figure 8 shows what sometimes happens when a protector is too
close to the TV and too far from earth ground - 8000 volts
destructively through the adjacent TV.
Bud also will say anything to avoid these scary pictures:
http://www.hanford.gov/rl/?page=556&parent=554
http://www.westwhitelandfire.com/Articles/Surge Protectors.pdf
http://www.ddxg.net/old/surge_protectors.htm
http://www.zerosurge.com/HTML/movs.html
Thanks to URLs provided here, we also have another example of
problems with plug-in protectors from the Gaston County Fire Marshall:
http://tinyurl.com/3x73ol or
http://www.esdjournal.com/techpapr/Pharr/INVESTIGATING SURGE SUPPRESSOR FIRES.doc
When selling protectors that don't even claim to protect from
typically destructive surges, then why properly sized them? Making
them smaller caused the naive to claim "a protector sacrificed itself
to save my computer". Effective protector earths surges, does so
without human knowledge, and remains functional.
Bud does not promote for effective protector manufacturers. So he
again posts a myth about 280 foot antennas. What had been well proven
in science papers was even demonstrated by Franklin on church steeples
in 1752. Everyone is strongly encouraged to review those scary
pictures. Read what the Fire Marshall in Gaston County has
discovered. Products that are missing an essential earthing wire so
also create other problems. 'Scary pictures' of protectors more
concerned with profits rather than for effective protection
demonstrate a well proven principle: No earth ground means no
effective protection.
