I guess you're saying that it isn't reasonable. But if a motor kick
can't do that, surely lightning can ... I guess ...
But Graham says that lightning protection is hopeless ... okay ...
Trivial surges such as motors must be made irrelevant by protection
already inside your power supply design. That is not found in
protector components. For example, you power supply must have
galvanic isolation for human safety. And that galvanic isolation is
made sufficient to made surge damage irrelevant.
Maybe once every seven years, a surge may occur that might overwhelm
protection that is standard in all appliances. Therefore earthing
makes that surge irrelevant. For example, a TV cable connects
directly to earth ground - not protector components - for effective
surge protection. That earth ground (quality of) determines the
protection. Surges so well earthing that protection inside all
appliances is not overwhelmed.
For other incoming wires (telephone, AC electric) direct earthing
is not possible. Therefore we install a 'whole house' protector with
that 'less than 10 foot' earthing connection. Even wire length too
long destroys the protection. Protection installed so that direct
lightning strikes find earth ground via that earthing electrode; not
destructively via electronics appliances or your design.
These requirements for electronics protection were even standard 30
years ago. Protection that is exceeded (as demanded by Intel specs)
in a properly designed ATX power supply.
Don't believe those myths that lighting damage is normal. When was
the last time your telco, their computer connected to overhead wires
all over town, was down for 4 days (no phone service) as they replaced
that computer? With maybe 100 surges during each thunderstorm, they
don't have damage. They also use a properly earthed 'whole house'
protector on each incoming wire. And up to 50 meter separation
between that protector and electronics. That separation also part of
the protection.
You may also want to learn from manufacturer data sheets about
standard ICs now required to meet 2000 and 15000 volt surge
protection. Those who don't learn from datasheets and other numbers,
instead, assume protection is not possible.
Those who posted nothing can protect from lightning? You now know
who has not first learned electronics design and other standards. But
they know anyway.
Meanwhile the fuse will take milliseconds to blow. Surge damage
completes in microsecones. Anyone with basic electronics knowledge
should have known this and posted it. Just another benchmark for
those who are making recommendations and yet don't even have basic
electronics knowledge. Fuses are not for electronics protection.
Their function - to protect you from a fire after electronics has been
damaged. Those other posters should have known this.
