surge arrester
Discussion in 'Electronic Components' started by [email protected], Jun 29, 2008.
  1. Guest
    Does the SDSA 1175 Surge Arrester installation require turning off all
    of the power? Or, can the SDSA be installed while the power is on?
    An electrician installed one on our control panel in the garage, but
    power was never cut off. Just wondering if he did it right......
  2. neon
    neon
    1,325
    Oct 21, 2006
    working with power on is never a good idea. but if you are carefull it can be done
  3. Sjouke Burry
    Sjouke Burry Guest
    He is still alive isn't he? If so, yes.
  4. Jamie
    Jamie Guest
    Makes no difference. And the only thing concerning here is the
    electrician that did it. I assume that he was still around to collect
    the money from you when the job was done ? :)
  5. Ross Herbert
    Ross Herbert Guest
    On Sun, 29 Jun 2008 10:13:19 -0700 (PDT), ""
    :Does the SDSA 1175 Surge Arrester installation require turning off all
    :eek:f the power? Or, can the SDSA be installed while the power is on?
    :An electrician installed one on our control panel in the garage, but
    :power was never cut off. Just wondering if he did it right......
    Since it is just a parallel connection across active and neutral it could be
    done without disconnecting power - provided all of the normal precautions were
    employed. ie. stand on rubber mat, wear rubber soled shoes, use appropriately
    insulated tools, handle one wire at a time and don't touch earthed objects.
    I have done similar things on my own house wiring and here we use 240Vac 50Hz
    with phase, neutral and earth connections. I must admit that on the odd occasion
    I have been a bit noncahalant about things and received a nasty whack though -
    but I am still here.
