Surface Mount parts kit
Discussion in 'Electronic Components' started by gcouger, May 10, 2007.
  1. gcouger
    gcouger Guest
    I have been away from elections a long time. I need to get the basic
    surface mount pop corn resistors, capacitors, diodes, LEDs, FETs,
    transistors, etc for some simple digital work.
    Long ago there were places that had inexpensive assortments of parts
    in the back of magazines. The magazines are gone and so or the dealers
    like Poly Pac's. More recently I found things on Japp's Chip-dir
    mailing list and sci.electronics and they seem to have fallen in to
    disrepair too.
    I expect that this is still a good place to ask where to find things
    like this.
    Gordon
  2. Me three.
  3. GPE
    GPE Guest
    Poly Pacs... now there's a name I haven't heard in years!
  4. http://www.vakits.com/
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  5. For good reason. They've been out of business for a LONG time.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  6. gcouger
    gcouger Guest
    I saif it had been a while and I had took id up again off a 20 year
    lay off then.
    Gordon
  7. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160112049232
    That was me getting 3050 surface mount resistors. I think it's a good
    price, maybe even worth going up against the UK to US exchange rate if you
    get lucky. The last lot of these went for £16, I got one for £6, and some
    went for £4 or less.
  8. Um, that's a quantity, NOT a size. >:)
  9. Mark Zenier
    Mark Zenier Guest
    There're still a number of mail/web-order outfits that took over
    Poly Junk's market niche.
    Jameco
    Digikey
    Mouser
    B&D Enterprises
    Circuit Specialists a.k.a. Webtronics
    JDR Microdevices (?)
    Mark Zenier
    Googleproofaddress(account:mzenier provider:eskimo domain:com)
  10. Mike
    Mike Guest
    For surface mount parts and grab bags go to Dan's Small parts...
    http://www.danssmallpartsandkits.net/
    He is mail order only, no phone or email orders. I know that is the
    old way but that is how he works...
    Great resource.
    Mike, AE6WA
  11. Guest
    Go to Ebay and search for seller "nfceramics". He also has an ebay
    store as http://stores.ebay.com/NightFire-Electronic-Kits.
    Seems to be what you are looking for.
  12. starfire
    starfire Guest
    Hi Gordon -
    If you just want an assortment of surface mount devcies like resistors and
    capacitors, check DigiKey. They carry kits covering ranges of parts. I've
    gotten the 0805 parts in both capacitors and resistors and they are pretty
    well done. Just go to their site and do a search on "resistor kits" or
    "capacitor kits".
    A couple of crutial items for starting surface mount projects... Make sure
    you have a well-lit area with a magnifying lens. Use very fine solder
    (~0.015" or so). Get a good pair of tweezers. Get some good solder wick
    (No Clean or Easy Braid in as small a diameter as you can find).
    Good luck. It's a lot of fun!
  13. That is http://www.vakits.com/ which has been recommended several
    times in this thread. They are located in Ocala, Florida. 352-237-4348
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  14. I can recommend this seller. He stocks a large assortment of assortments
    of surface mount kits. Even zero ohm resistors. When I first saw that I
    thought it must have been a typo but someone at work explained how they
    are used.
