surface mount bypass
Discussion in 'Electronic Basics' started by aman, Feb 22, 2005.
  1. aman
    aman Guest
    Can surface mount film capacitors be used as bypass capacitors in place
    of ceramic capacitors. Is there some rule that bypass capacitors have
    to be ceramic ?
    I want to use all surface mount components on my board.
  2. No. But I am curious as to why you believe a film
    capacitor should be used instead of ceramic.
    Easily doable these days.
  3. aman
    aman Guest
    I want to use some bypass capacitors. I am not able to find any ceramic
    bypass capacitors at digikey. Some datasheets specifically say use
    "ceramic 0.1uf".
    Do you think it is fine to use thick film SMT 0.1 uF in this case.
  4. Digikey sells plenty of ceramic surface mount caps.
    In their index they are called "Ceramic, Chip" and
    "Ceramic, Multilayer Chip".
    Yes. But you will get better volume efficiency and
    cost from a ceramic SMT. There is a reason they
    are so popular for that application.
  5. aman
    aman Guest
    That answers my question. Thanks Larry
