Surface maount and valves/tubes.
Discussion in 'Electronic Repair' started by N_Cook, Jul 23, 2008.
  1. N_Cook
    N_Cook Guest
    Just repaired a tube amp , problem unrelated to this.
    But it seemed odd to me to have valves , in inverted
    orientation , ie under a pcb with SM resistors on it.
    Anyone foresee temperature cycling problems/ dislodged SMD in the future
    with such arrangements.
  2. Dave
    Dave Guest
    As they say "If it can be done, some fool will do it". Given that heat
    rises, I see no benefit whatsoever to putting a tube which converts 70% of
    the electricity fed through it to heat underneath a PCB. All it's going to
    do is shorten the life of the PCB components and, quite possibly, the tube.
    There's a reason why most tube amps have the tubes exposed or covered only
    by a mesh grille...
    just my 2 cents.
  3. boardjunkie
    boardjunkie Guest
    What the hell kind of amp was it??? Just so I can refuse repairs on
    that kind of garbage.....
  4. N_Cook
    N_Cook Guest
    onhttp://home.graffiti.net/diverse:graffiti.net/
    Laney LC15 from 2002
  5. Arfa Daily
    Arfa Daily Guest
    Well, I think maybe you've answered your own question there. If it has done
    six years so far without a problem of the type you are envisaging, I doubt
    that it's going to develop one. Those sm resistors are subjected to a lot of
    heat and various levels of thermal cycling when they are first fitted,
    that's a lot more intense than anything that the valves are going to
    generate in normal service. Many amps that I work on, have the output valves
    fitted upside down in a pcb-mounted holder, and it doesn't seem to cause a
    problem with either the service life of the valves, or the pcb above them. I
    have, however, had bad joints on the output valve holders of several Fenders
    recently, that have been manufactured with lead-free solder. I don't know if
    this is as a result of thermal cycling or not, but I rather suspect that it
    is a 'normal' lead-free production problem that we are getting used to
    seeing on all sorts of equipment, now.
    Arfa
