surface light on oven
Discussion in 'Electrical Engineering' started by snow, Jul 27, 2007.
  1. snow
    snow Guest
    About two weeks ago my surface LED light on my oven stays on all the time.
    No effect when I cook...light just won't go off when I turn off any of the
    top surface elements. Is this a short circuit, or something else going on?
    Any info appreciated.
  2. Guest
    If this is the type that normally would come on shortly after heat comes on
    and go off only after the elements cool, then it could be a heat sensor gone
    bad.
  3. snow
    snow Guest
    When ever I turn on or off any of the four elements the surface light
    indicator won't go off. It stays on all the time. I call it a dummy light as
    I think all it indicates is I turned on one of the stove top elements.
