I have a 220 volt, 20 amp change-over interface relay switch which sometimes causes a surge when the coil is activated. When this happens, it wipes the memory of a digital time-clock on the same circuit. I want to suppress the surge by absorbing it in a diode. The actual current draw though the relay switch is less than 3 amps.
Can anyone tell me what sort of diode I need to achieve this ? I imagine that the leads from each side of the diode would be connected to the positive and neutral terminals of the relay switch, but I do not know what to ask for in the component shop ! I have searched the index for diodes but there are thousands of them ! What should I look for ?
Thanks for any advice.
