"Anon Email"
On the back it says 100V cos it is made for Japan or other place with that
power voltage.
Probably got it on eBay.
No, I bought it in Japan when I was there,
** What a PITA prick you are for not saying that originally.
I bought a transformer which transforms from 240V (I'm in Australia),
to 115V. I couldn't find a transformer that transforms down to 100V
specifically. The speaker works fine at 115V. Am I likely to blow the
speaker if I up the volume too much?
** Go ahead - make MY day ...............
Japan is a bit weird,
** So would you be
- if someone dropped two fucking nukes on you.
they have voltage supply at 100V, but the
current frequency is 50 or 60 Hz depending on the region.
** Depends where the nukes landed - dickhead.
From what
I've read on the Internet, a difference of about 15% in the supply
voltage is OK, and the current frequencies will not affect equipment
that's not sensitive.
** Yawnnnnnn ....
It don't matter - if it don't matter ....
I also noticed that the desktop computer I used
to use in Japan was rated at 115V - I was curious as to why this
didn't blow the power supply.
** Huh ???
Totally off with the pixies....
Am I right about the 15% acceptability
range, or was that incorrect info?
** Is your prick +/- 15% compared to the next guy's ??
Enquiring minds need to know......
...... Phil
