Hi Guys,
I wanted to get some advice about capacitors in a power supply which are getting super hot....!
I bought myself a secondhand Xbox One console which turns out the PSU is not the original Microsoft one but a Chinese aftermarket product.
It works but the case gets very hot on the top, on the bottom there are two large areas of the case with slight visual disfigurement, there is a slight melty plastic smell after 20 minutes of use and the fan noise varies from whisper quiet to squeaky at times.
I opened up the PSU and inside it looks like it is constructed to a budget with a cheap fan without any airflow guide.
The 3 main capacitors seem to be;
1 x 150uf 400v 85degree on the AC side - looks absolutely fine
2 x 2200uf 25v 85degree on the DC side - one is bulging and both have singe marks around the base on the PCB
So, I put the PSU back together and played the console for an hour - the PSU was hot on the outside with plasticky burning smell. I took it apart to measure the temperature of the capacitors with my infrared thermometer;
On the AC side the large capacitor is touch warm at 40-45 degrees C.
On the DC side the 2 capacitors are showing as 120-130 degrees C - you can feel they are super hot just by hovering a finger above them.
So my question is what would cause this capacitor situation in my PSU? (crap caps/inadequate cooling/something else)
Should they have failed by now? (85 degree caps regularly heating up to 130)
Should I try a quick fix and replace them with uprated ones - 2200uf 50v 105degree ones?
Thx.
Mark
Thx.
Mark
