Suntan brand capacitors bought from Jaycar
Discussion in 'Hobby Electronics' started by Sylvia Else, Jul 10, 2011.
  1. Sylvia Else
    Sylvia Else Guest
    I'm frustrated to discover that a couple of 1000uF 16V electrolytics
    that I bought from Jaycar a few years ago to repair a video card now
    have bulging tops and will have to be replaced. They are "Suntan" brand.
    It appears from a search that I'm not the first to have trouble with them.
    Sylvia.
  2. **I ceased buying 'mission-critical' components from DSE and jaycar many
    years ago. Caps from WES are decent enough for day to day service and
    Farnell (no, I refuse to call it Element 14) or RS Components can be traced
    and are of high quality.
  3. Sylvia Else
    Sylvia Else Guest
    I'd feel a bit silly ordering 2 capactors online, and having them sent
    by courier.
    Still, if that's what it takes to get reliable components...
    Sylvia.
  4. **I see your point. Try WES Part #1000TKR16. It is a 105 degree C component
    and I've found them to be excellent quality. Very low leakage too.
  5. Sylvia Else
    Sylvia Else Guest
    Well, I don't actually know what role they're performing, but there's no
    inductor in sight, so they're not part of an SMPS.
    Sylvia.
  6. Sylvia Else
    Sylvia Else Guest
    And being as this is a video card, it's power supply inputs are DC.
    Sylvia.
  7. Tom
    Tom Guest
    Both motherboards and more powerful video cards have DC to DC SMPS that
    converts 5V (maybe 3.3V) into whatever Vcore the CPU/GPU needs. They
    need low ESR electros.
    Tom
  8. **If you wish, I can add a couple of caps onto my next WES order (Thursday
    or Monday). I can then post them to you at cost. For the values you cited,
    that's $0.45 each. If you want the caps that are specified for SMPS, they're
    $0.60 each. Add a Buck for postage to you.
  9. Sylvia Else
    Sylvia Else Guest
    Thanks, but no. I'm not even using the video card at the moment. I won't
    repair it unless I find a reason to use it again.
    Sylvia.
