T
TD
I need to design a miniature rigid pcb that will have a silcon die
wirebonded to it and then take the signals out of this board using a
flex cable to a 4in x 4in 4-layer rigid FR4 board (I have already
designed this big board and laid out except for the signals coming in
from the flex cable). at the bigger board end I intend to have a ZIF
connector for the flex cable. There are 20 signals that the flex cable
need to carry. My question is,
there are differential signals coming out from the smaller pcb, they
must be routed together right ? i know they must be placed close to
each other and maintain some distance from other signals. but the
problem is i am using 3 mil traces and they are separated by 3 mils (
because of the restriction on the size of the board). so i can have
other signals at 3 mils from the differential signals....how do i take
care of this ?
i am thinking of using a flex cable to take out the signals. does this
usually need to have all the signals on one layer ( I know there is
rigid-flex board but i heard its very expensive )
what about the impedance mismatch, since i will be routing the signals
at 10 mils on the bigger board...
i am having power and ground signals brought in through the flex cable.
i can and should provide a solid ground plane. but the traces that
carry the power to the pads i cant make them more than 5 mils. how do i
overcome this coz there will be a voltage drop. the supply current
drawn is aroun 30 mA. please provide any suggestions..thanks !
care of this ?
