Suggestions for auto plug disconnection and protection
Discussion in 'General Electronics Discussion' started by bobdxcool, Apr 7, 2016.
  1. bobdxcool
    bobdxcool
    98
    Mar 9, 2012
    Hi. I am using a motorized AC power cable reel for my electric charging station. The AC cable reel uses a industrial socket which is connected to the plug in the vehicle. I am facing two challenges here. One is that the socket gets damaged with frequent usage as it brushes against the road. To solve this I was thinking of a something like circular ring roller around this socket with ball bearings. Can anyone suggest something like this online or please let me know if there are better ideas .
    Attached a picture of the socket being used.
    The second issue I face is in case the cable with the socket isnt removed from the vehicle and the vehicle drives away, there is a possibility of damage to entire charging unit as motorized cable reel might get pulled out of the charging station due to the force created by the vehicle moving away. I would like to detect this and cut off a part of the socket and cable. I was thinking of something like another socket and plug behind the socket that fits into the vehicle, so that the secondary plug and socket would automatically disconnect from each other due to the force created by the vehicle moving away. Are there any plug and socket combinations that can do this ? Or, is there any better way of doing this?
  2. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Two simple solutions:
    1.Prevent it from "brushing against the road".
    2.Make sure you disconnect it properly before the "vehicle drives away".
  3. bobdxcool
    bobdxcool
    98
    Mar 9, 2012
    Actually there is an auto disconnection mechanism in the vehicle which disconnects the socket, but in case it fails, I was thinking of the mechanism explained above.
  4. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    It would be very strange if you find one.
    Have you ever seen a car yank the fueling hose in a gasoline station?
    I have,not a pretty site:eek:
