Stupid question of the day....
  • Thread starter AllTel - Jim Hubbard
  • Start date
John Fields
Wonder how bad it is for graphite rods used in electric furnaces? Of course
graphite has a much higher melting temperature so it can withstand a strong
gradient. But graphite, with its lower thermal conductivity and higher
resistivity, probably develops a very strong gradient. Coupled with the
temperature coefficient of resistivity, it might make for an interesting
current distribution. Even for DC applications.
John Fields
You're full of shit, boy. If you had read the thread, you would
have noted where I said that I have had Nasa's Laser Disc on the
subject for over 15 years.
John Larkin
Nah... The thermal conductivity of a film coefficient for air is not the
same as the thermal conductivity of air. The thermal conductivity is only
relavent in a very thin layer against the surface (much less than 10 mm).
Moving outward, the viscosity and velocity of the air become dominant.
Given the film coefficient of air against a vertical surface of about 25
W/(m^2-K), I make it out to only be about 8,000 C. ;-) Having forced air
convection (or a good 'stiff' wind) can improve the film coefficient to
almost 200 W/(m^2-K) (down to 1,000 C ;-). Water cooling can be as high as
5000 to 10000 W/(m^2-K) (as low as 20 C).
I did hedge my number with "very roughly", figuring I could be 2
orders of magnitude off and still make the point.
But larger wires, and those of Al can develop such a gradient more easily.
And true, boiling heat transfer can be several orders of magnitude better,
but one then has to worry about exceeding the critical heat flux (also known
as 'departure from nucleat boiling', 'boiling transition', or 'dryout').
Whether the water is circulating or not, and how far the bulk water
temperature is from saturation also become important (i.e. becomes a real
engineering nightmare).
A spiral of #10 bare copper wire in a plastic garbage can full of
water makes an impressive dummy load, up until the water gets hot
enough to melt the plastic can. Then the hot water gets loose. Keep a
good chair handy.
The industry has a long history of success using pressurized hydrogen. Most
large generators and their connections to step-up transformers are cooled
this way. Much better cooling than plain air, allowing much higher current
densities. And with the same material properties, stronger temperature
gradients.
Except all of the H2-cooled gen-xfmr leads that I've seen use hollow
conductors with H2 forced through the center as well as surrounding the
outside. Similarly, the water-cooled conductors that I've seen are those
found in generators and the water flows down the center of the hollow
conductor. Not much of a temperature profile when the cross-section is
mostly cooling water ;-)
True, but one usually designs to avoid melting, much less boiling.
Fact is, in 60hz applications, the usual design restrictions regarding
skin-effect overshadow any problems with centerline temperature concerns.
Perhaps engineers working with high-current DC applications are more
concerned with the temperature gradient issues. But I suspect it is still
small for good thermal conductors like copper.
I jumped into this fray when 'TokaMundo' said, "In a wire,....would show the
wire at the same temp from center to outer surface". I think we agree this
is wrong. And I agree that the temperature gradient is not severe for
conductors made of Cu or Al under normal circumstance such as air cooling.
But *some* gradient *must* exist, otherwise the centerline temperature must
increase (due to heat generated and not conducted away) until a gradient
begins to conduct heat away as fast as it's created by the electric current.
True. But below the melting point, it isn't hard to approximate the
variance with a low-order polynomial using temperature alone as the
independent variable. I would think this would make it relatively easy to
incorporate into the integration. Haven't tried it though, so who knows???
daestrom
My conclusion from this thread is that skin effect can be important at
60 Hz in entirely practical situations, and thermal gradients in
copper or aluminum conductors are inconsequential unless the current
is high and the cooling novel. We're doing some thermocouple stuff
just now (a simulator module and a complementary measurement gadget,
for jet engine testing) so thermal stuff is on my mind.
I've done a little superconductive/cryo work, where things are very
different. Here, the thermal conductivity of metals changes radically
as a function of temperature, so the net heat flow of, say, a
stainless or manganin leadwire from 4K up to to room temp is
determined by a complex integral (the bottom line of which,
fortunately, you can just look up.)
Yeah, the Toka guy is weird. He insists on crudely insulting anyone
who disagrees with him, and he's usually wrong. Some people seek and
need public humiliation: Usenet pain sluts, as it were.
John
John Larkin
That's why I said *net* heat transfer.
Yeah. The truck pulling up outside brings no joy if it can't unload
the beer.
John
T
TokaMundo
So you know some of what was known 15 years ago, so what? do you
think nothing new has happened since then?
No, but your retarded ass apparently thinks that that is when I
stopped learning anything about it. How stupid does that make you?
Pretty fucking stupid.
Learning never stops. At least in most cases. Your an exception.
T
TokaMundo
You're right, I never did get into laser discs much. No interest,
plus I was too busy designing equipment to go to the bottom of the
Marianas Trench instead of watching somebody else's stuff.
Yeah right. You were a technician... oh... strike that... an
assembler... oh wait... that's right... you swept the floors in the
lab. Sound familiar, fuckhead?
D
daestrom
John Larkin said:
On Sun, 07 Aug 2005 16:10:37 GMT, "daestrom"
good chair handy.
So your plastic garbage can melts at 212F, or you let the wire touch the
can?
When I was in the shipyard, we load-tested 2 and 4 MW units by dipping three
'blades' of steel into a tank filled with tidal water standing on the pier.
Adjusted the load by controlling the depth of the 'blades'. Nice load but
had to run a 'fill' line to keep the tank topped off ;-)
Yeah, ditto. Back on 8/1 I suspected this when I said...
But this discussion forced me to 'sharpen the pencil' and do the actual
calculus. Turns out it is a pretty small effect in most practical
conductors (but not 'Toka's zero). But those graphite ones you mentioned in
another thread could be interesting.
Yeah, especially when solid 'phase-changes' take place. Some steels undergo
some interesting crystaline changes from 'body-centered cubic' to
'face-centered' at high temperatures and actually absorb a far amount of
heat doing it with no appreciable temperature rise. So I can imagine such
'shifts' in thermal conductivity can occur.
daestrom
T
TokaMundo
There ya go with those veiled threats again,
Bullshit. It isn't a threat, veiled or otherwise, now or ever, so
even your "again" bullshit is just that.... bullshit.
even after ratting out
Steve Walz for the same thing, you effete little hypocrite.
The shit the other asshole pulled were direct threats. Big
difference, Johnny come stupid.
Like I said, there is a world of difference between the shit he
pulled and what you have quoted me posting.
I was telling you that you wouldn't be such a mouthy **** if you
were sitting right next to me. Which constitutes essentially me
telling you that your a no more than a mouthy little wuss. He was
making direct, blatant threats. There are at least two orders of
magnitude of difference between the two.
T
TokaMundo
good chair handy.
That's funny since your position supports what I said about the
gradient being negligible, not the full on slope that daystruck
equates.
T
TokaMundo
I believe I said "near zero", Daystruck. I also believe that my
analogies were and are closer to the truth than the curve you
declared.
Someone out there must like them for them to be a product.
T
TokaMundo
That's why welding works the way it does, and soldering works the
way it does.
John Fields
Not at all. From every indication, so far, it seems you _can_
accept a modicum of instruction, but then you plateau out.
Sometimes I think it's because it's a little glass and can't take
much before it overflows, and sometimes I think it's because you
don't like who's doing the pouring. In any case, your capability
for intellectual development seems to have been crippled, somewhere
along the way, and now you're left with little but a tattered bag
half-full of crude insults which you use over and over again
without, seemingly, even knowing that that's what you're doing.
You, apparently, are trying to teach me that you don't know how to
punctuate properly. That's old knowledge, but it seems you have an
inner need to continually make errors in order to be noticed/
abused/corrected.
John Larkin summed it up quite nicely, I think, by likening you to a
"newsgroup pain slut". Or was it "internet pain slut"? I don't
remember, but it fits, either way.
T
TokaMundo
Get it through your head, you retarded ****. I don't need your
assessments.
T
TokaMundo
Same old fat troll fucktard bullshit. When are you going to stop
trolling, John. Grow the **** up.
K
keith
assessments.
Perhaps you don't _need_ them to survive on the plnet, but you would do
well to listen. Of course you know-it-all, so why would you "listen",
even to your superiors.
K
keith
I suggest that you figure out who your nemisis is! He will bury your
slimey ass in anything technical! ..which isn't all that hard, really.
John Fields
T
TokaMundo
You're an idiot. You also made a spelling error, yet yours won't be
highlighted by the troll ASS. Starting to see a pattern, dipshit?
You fucking correct all retards are real funny to watch spin in
little convoluted circles.
