stupid question from a newbie
Discussion in 'Electronic Design' started by [email protected], Mar 11, 2007.
  1. Guest
    I'm working on a circuit and I'm doing some testing. I'm basically
    following a set of directions. I'm unsure what the directions mean
    and I'm hoping someone here can help me with it.
    I'm using a voltmeter on a 3-prong 10k potentiometer, The directions
    say the following:
    "a digital voltmeter should be connected across the potentiometer top
    and bottom (not the wiper)"
    I'm not sure what it means by top and bottom. The pot has three
    prongs. Anyone know what this terminology means?
    Steve
  2. Phil Allison
    Phil Allison Guest
    ** Means the two ends.
    What is "top" and "bottom" depends on the circumstances.
    The "bottom" usually means the end that connects to circuit ground or a
    lower voltage than appears on the top.
    ......... Phil
  3. BobG
    BobG Guest
    Measure from the wiper to either other terminal with pot full cw and
    full ccw. One reading will be zero, one will be the resistance of the
    pot.
  4. Eeyore
    Eeyore Guest
    Are they Massive Prongs ?
    Graham
  5. Eeyore
    Eeyore Guest
    We call them terminals.
    Wiper, top and bottom ?
    Yes, the one in the middle is going to be the wiper. Actually very, very rarely
    it might not be but I'm sure it will be in your case.
    The top and bottom refer to the conenctions to the pot's 'track'. The wiper is
    the moving connection.
    Graham
