Stumped - please help identify this connector
Discussion in 'Datasheets, Manuals and Component Identification' started by WestyJon, Feb 13, 2015.
  1. WestyJon
    WestyJon
    4
    Feb 12, 2015
    I need to replace this well-worn connector and its pins. There is no part list that identifies the connector. I've tried at length to figure out who made/makes this part, with no luck.
    You can see by the closeup photos that the pins are made from flat metal that is bent back on itself to form a sort of compressible contact. The housing has a tab with an apparent screw hole and little tabs/feet on the opposite side. It's very roughly about an inch square in Length/Width and about 3/8 inch or less in height.
    Does anyone here have an idea who made/makes this? Any insights would be appreciated!!
  2. chopnhack
    chopnhack
    1,573
    354
    Apr 28, 2014
    You might want to contact Tyco
    They have many connectors that look similar.
    Another option would be to contact Digikey and see if they have any matches. You can go through their website as well and search for your connector based on how many pins, etc.
    Molex makes many as well - most of these companies will have a parts interchange between their competitors products. Good luck.
  3. Bluejets
    Bluejets
    5,250
    1,100
    Oct 5, 2014
  4. WestyJon
    WestyJon
    4
    Feb 12, 2015
    All good suggestions, but those are all places I've already looked through at length, but it was a blind search and they carry a jillion varieties. That's why I was hoping someone would recognize at least the family or style so as to at least narrow down the search a bit. The case and pins all seem different than anything I found so far.
  5. chopnhack
    chopnhack
    1,573
    354
    Apr 28, 2014
    I hear ya, that is why I posted the first link. Tyco support is actually really good. You might get lucky with them. They have a chat so you could link them to the photos and see if they can source it for you. Digikey can be hard to navigate sometimes, but customer service their has been top notch each time I have called.
  6. WestyJon
    WestyJon
    4
    Feb 12, 2015
    Those pins appear identical in shape to the ones used in this connector, but I don't see where on that website it shows who the manufacturer is.
    Also, I see they are rated at 1A and I know this circuit carries currents of at least 10, perhaps 15A. I should also mention that I think 18 ga. wire is used on this harness.
  7. WestyJon
    WestyJon
    4
    Feb 12, 2015
    Oh, I see ... I'll plan to make contact with them both tomorrow and send photos. Thanks!
  8. KJ6EAD
    KJ6EAD
    1,114
    159
    Aug 13, 2011
    I've seen those before so they're probably either AMP or Molex. Look for a very small molded series number on the edge of the housing on the wire entry side.
    By the way, the ones you show are not crimped correctly. The insulation strain relief crimp is crimped on the conductor.
  9. hevans1944
    hevans1944 Hop - AC8NS
    4,647
    2,168
    Jun 21, 2012
    Can you not simply replace both mating connectors with something else, rated for the current you expect to pass? As you noted, there are jillions of this style available.
    shrtrnd likes this.
  10. shrtrnd
    shrtrnd
    3,827
    524
    Jan 15, 2010
    I'm with hevans1944, ESPECIALLY when you know that the the current you're handling is greater than what the connector is rated for.
