Normally there will be some jitter on the pulse train, and averaging the period time over some pulses will filter out the most prominent jitter.
Don't use too many samples since changes in RPM will then be delayed. It depends on the quality of your measurement setup. If your program monitor the stability of the values, and they are good, you can reduce the sample interval, and speed up the update. It all depends of the dynamic of the motor and the RPM changes.
As (*steve*) said measure the whole period as one sample.
In short the procedure is simple.
The timer system has a freerunning counter that can be read. You setup the interrupt service routine for interrupt at the positive or negative flank of your input, and log the counter at every interrupt. The value should be put into a small ringbuffer, and a new value flagged, or you can calculate the ticks directly. In your background program you process the values in the ringbuffer, and subtract the buffer value(n-1) from value(n). This gives you the number of counter ticks one period has lasted.
You know how fast your counter are running, from your setup of the timer unit, and you can calculate the time(p) of the period. If you have one period/rotation, your RPM = 60/time(p)(in seconds). If your time(p)=0.01s (10ms) your RPM is 60/0.01=6000
