Strobe Lights.
Discussion in 'Electronic Repair' started by [email protected], Feb 9, 2009.
  1. Guest
    I am watching How It's Made on the SCI channel.The tv program guy said a
    strobe light can be ajusted to make it appear a moving fan blade has
    stopped.Is there another way to do that without the flickering of using
    a strobe light?
    cuhulin
  2. Guest
    The "flickering" is what makes the blades appear to stop. If the
    light flashes when the blades are in exactly the same position they
    were in the previous time the light flashed, you will not perceive
    that the blades are turning.
    This can be a safety hazard when machinery running at certain speeds
    is illuminated by fluorescent lights - the on and off of the
    fluorescent bulb with every cycle of the AC voltage can make the
    machinery appear to be stopped (yes, I know it's a simplified
    explanation).
    John
  3. Sure: how fast can you blink your eyes?
    Personally, I like Vista, but I probably won't use it. I like it
    because it generates considerable business for me in consulting and
    upgrades. As long as there is hardware and software out there that
    doesn't work, I stay in business. Incidentally, my company motto is
    "If this stuff worked, you wouldn't need me".
    - lifted from sci.electronics.repair
  4. CJT
    CJT Guest
    Spin yourself at the same speed as the fan.
  5. Yukio YANO
    Yukio YANO Guest
    It just occurred to me that the strobe lights and circuits take a
    finite amount of time to charge ! and discharge very quickly to give the
    flashing strobe effect.
    It also occurred to me that superbrite white LED's should fire very
    quickly so by using a 555 timer and an appropriate driver would give you
    a quick strobe ! Without that recharging delay !!
    I will have to try this on my testbench soon !
    Yukio YANO
  6. Could work, would be interesting, but wouldn't be able to touch a xenon
    tube for brightness.
  7. GregS
    GregS Guest
    Nothing new. You can pulse to the LED's peak rating. The longer the pulse the brighter it
    appears.
    You could also use LCD glasses to view the fan.
    greg
  8. PeterD
    PeterD Guest
    Turn off the fan. The blades will be clearly stopped.
  9. Guest
    I work on and do tune ups on my own vehicles.I know about using an auto
    strobe/timing light.
    When I was watching that How It's Made tv program, I figured it would be
    ''cute'' if the rotating fan blade on my old antique electric table fan
    could appear to stop rotating.That is what the How It's Made program
    showed on tv.I still think it is a ''cute'' idea though.
    cuhulin
  10. GregS
    GregS Guest
    Just keep it away from kids.
    greg
  11. Guest
    I like those Western movies, when the wagon wheels look like they are
    running backwards.
    cuhulin
  12. They were. Didn't you know they shot all action scenes backwards back then?
    You can imagine how hard it was for all them actors to learn to talk
    backwards.
  13. Franc Zabkar
    Franc Zabkar Guest
    I have a Ministrobe kit designed by Electronics Australia in August
    1997. It uses exactly those components.
    - Franc Zabkar
  14. Dave
    Dave Guest
    Sure. Turn the fan off.
  15. GregS
    GregS Guest
    Grab it.
  16. Guest
    It is 70 degrees outside right now.The old antique Hunter electric fan
    on the end table by doggy's end of her couch is running.
    cuhulin
  17. jakdedert
    jakdedert Guest
    Stick your nose in it....
    jak
  18. Guest
    Outch!
    cuhulin
  19. whit3rd
    whit3rd Guest
    Yes, you can hold a strobe disk up to your eye.
    This is a painted-black disk with one slot, spun
    (often by hand) so as to block a peephole. Instead
    of turning the light on/off, you block your line of sight to the fan
    except during the slit-crosses-the-peephole instants.
    It doesn't have to be your eye, of course, you can
    put a camera behind the peephole and observe the photograph
    in any lighting you find desirable...
  20. whit3rd
    whit3rd Guest
    Maybe, maybe NOT. The 'white' LEDs use blue or UV emitters
    and phosphors, so part or all of the light output is delayed.
    A gas-discharge lamp (like xenon or even neon) has better
    timing control. It also tolerates high-brightness/low duty cycle
    better than a semiconductor.
