Stripping Ribbon Cable
Discussion in 'Electronic Basics' started by eromlignod, Nov 21, 2006.
  1. eromlignod
    eromlignod Guest
    Hi guys:
    I've got an application where I'd like to strip the ends of a ribbon
    cable, insert them through holes in a PCB and solder them in
    permanently. The holes are spaced at the same pitch as the ribbon
    wires. Is there an easy way to strip the ends without using a
    specialty tool?
    Don
    Kansas City
  2. feebo
    feebo Guest
    go get an inline IDC plug & socket - rather than messing about with
    stripping and soldering - much neater solution.
  3. Don McKenzie
    Don McKenzie Guest
    when you say they are at the same pitch as the cable, you mean at .05"
    spacing. are these holes in a single row on the board, or dual row?
    Don...
    Don McKenzie
    E-Mail Contact Page: http://www.dontronics.com/e-mail.html
    Crystal clear, super bright OLED LCD (128x128) for your microcontroller.
    Simple serial RX/TX interface. Many memory sizes.
    http://www.dontronics-shop.com/product.php?productid=16460
  4. Phil Allison
    Phil Allison Guest
    ** Groper Alert !
    ** Depends what YOU call a specialty tool.
    One of these does all sorts of wires & cables plus strips ribbon cable up
    to 10 strands at a go.
    http://www1.jaycar.com.au/productVi...d2=&pageNumber=&priceMin=&priceMax=&SUBCATID=
    ......... Phil
