Strength master Treadmill showing error AC 6
Discussion in 'Power Electronics' started by malie, Jul 30, 2020.
  1. malie
    malie
    4
    Jul 30, 2020
    I have a strength master Treadmill with a 3 phase, 3.0hp motor, it keeps showing error AC 6 when it's switched on. Any idea what this error. And how I can go about to fix it.
  2. 73's de Edd
    73's de Edd
    2,939
    1,246
    Aug 21, 2015
    Sir malie . . . . .
    This has been covered once before . . .see if this is possibly also being your situation.
    This is will be the speed sensor not responding.
    Take the motor cover off.
    Find the small belt coming off the motor and on to the roller.
    Look on the side of the front roller for a magnet, you might just find a vacated hole, if this is the case, the magnet has fallen out and will be stuck on the inside frame somewhere.
    Glue it back in that cavity and test machine.
    73's de Edd . . . . .
    An ounce of valid application is worth a ton of vague abstraction.
  3. malie
    malie
    4
    Jul 30, 2020
    Thanks for your response,
    I have checked the Treadmill it doesn't use a speed sensor I think the Treadmill having a a 3 phase motor is controlled using the inverter.
    Also with speed sensor problem the treadmill runs for about 6 seconds and then stops( according other post). This one doesn't even run. When you power it the buttons and display lights up and then it shows AC 6 then nothing works.
  4. bertus
    bertus Moderator
    1,150
    435
    Nov 8, 2019
  5. malie
    malie
    4
    Jul 30, 2020
  6. bertus
    bertus Moderator
    1,150
    435
    Nov 8, 2019
    Hello,
    The Strenght master website does not show the TR-series.
    I can find some lifespan TR5000 manuals, but those do not show the AC 6 error.
    Those only mention the DC 6 error:
    Problem: “dc-6” appears in the display.
    Solution: Turn the treadmill desk power switch off. Unplug and re-plug the
    connections made in Step C on page 22. Make sure the thumb screws are
    properly tightened. Turn the treadmill desk power back on and check to see if
    it functions properly.
    Or this from an other manual:
    Problem: “UART” or " “dc-6” appears in the display.
    Solution: Turn the treadmill power switch off. Unplug and re-plug the
    console connector to the treadmill. Make sure the thumb screws are properly
    tightened. Turn the treadmill power switch back on and check to see if it
    functions properly. Also make sure the treadmill is plugged into the wall
    socket and not into an extension cord or power strip.
    Bertus
  7. malie
    malie
    4
    Jul 30, 2020
    Thanks Bertus,
    I will try that.
