Stray inductance of mutual inductors in SPICE
Discussion in 'Electronic Design' started by Robert Latest, Dec 13, 2006.
  1. I know: K goes up, Lstray goes down. But what is the precise
    mathematical relationship between the two and the inductors?
    Thanks: robert
  2. Tom Bruhns
    Tom Bruhns Guest
    Try the Wikipedia explanation at
    http://en.wikipedia.org/wiki/Inductance, starting about 2/3 of the way
    down the page at the part titled "mutual inductance." In short, two
    inductors which share some magnetic field have mutual inductance, M.
    Remember that in an isolated ideal inductor,
    V = L * di/dt
    (It may also be useful to recall that Faraday's Law says that there is
    an electric potential around any closed loop which is proportional to
    the rate of change of magnetic field enclosed by that loop...)
    But when you add mutual inductance M between L1 and L2, where i1 is the
    current in L1 and i2 the current in L2,
    V(L1) = L1 * di1/dt + M * di2/dt.
    Then the coupling coefficient k is given by
    k = M/sqrt(L1*L2).
    Clearly, if k=1, 100% of the magnetic field of L1 is shared by the
    turns of L2, and vice-versa; and if k=0, none of the magnetic field of
    either inductor is shared by the turns of the other. This gives some
    clues about how to maximize k. Can you deduce that k is the fraction
    of the magnetic field which is shared?
    Cheers,
    Tom
