strange sine wave
Discussion in 'General Electronics Discussion' started by pccmd, Aug 2, 2009.
  1. pccmd
    pccmd
    8
    Jul 28, 2009
    Good Day.
    I have attached dual trace in which upper is from first op amp stage(square wave) and lower is second stage output, supposedly a sine wave. The design from National Semi. calls for a high speed, low noise op amp lmh6622 and 1% resistors, but I used 1458 I have already and common 5% resistors and cheapo capacitors. Supply +9v and -9v both checked.
    So the questions:
    1) could all that be why the waveforms are asymmetric relative to X-axis, and why the duration of (+) and (-) portions are so unequal?
    2) what's with the notch in lower trace corresponding to where the "square wave" goes (-) ?
    Thanks for assistance and I hope I haven't exasperated anyone with this posting.
    CC
  2. neon
    neon
    1,325
    Oct 21, 2006
    it looks fine to me except ther amplifier has serious rail problems. fix that first. then you may see a not so simetrical sinewave.
