S
Sam Goldwasser
William R. Walsh said:Hi!
See my other reply. Do you have a light switch that glows when you turn it
off? This will place a small amount of current flow across the lamp, which
may make it flicker.
It may result in a slight amount of wear on the bulb, but I doubt the change
in lifetime would ever be noticed.
This I wouldn't be so sure of. Startup is hard on fluorescent lamps.
In many cases, these bulbs contain a small switchmode power supply. Such a
power supply will have a transistor, some type of controller, a small
transformer and some support components (of which a capacitor would probably
be included). Others use a much simpler transformer design.
The transformer design will not experience this phenomenon.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
