M
motor man
I have a 1990 Jenn-air electric oven. Robertshaw controller. The oven
control works fine. The oven will not self clean as the broiler element
shuts off before the oven reaches cleaning temperature. The broiler
element doe sabout 60% of the heat for cleaning. It is not ( replaced
with new ) the oven sensor or the over temp protoective switch (
bypassed) . My assumption is that the controller has somehow set the
max temp to a much lower temperature than the cleaning cycle temp of
around 900F. Has anyone worked on these 1990 controllers and if so do
you have ideas as to how to reprogram the set points? Help please.
