Strange D-sub connectors.
Discussion in 'Electronic Repair' started by Sam Goldwasser, Dec 12, 2004.
  1. I'm looking for a few pieces of each of the following connectors. Solder
    cup preferred, or crimp with pins. Used is OK as long as they can be
    reused. These are in D-sub (DB) shells but with strange combinations
    of pins. Some pins are fat for high current while others are normal size,
    and one is a mini coax.
    In the ASCII diagrams below, "O" is fat pin; "." is normal pin, "C" is
    mini coax. Shells not shown.
    7 pin male and female which look like:
    O . . . O (DB15 shell)
    21 pin male and female which look like:
    O O . . . . . . . . . O O (DB37 shell)
    5 pin male and female which look like:
    O O O O C (DB25 shell)
    I didn't see anything like these in Jameco or Digikey. Aside from looking
    for a diagram that matches, I don't even know what to call them to search
    properly. Or, perhaps they are custom.
    Thanks.
    --- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
    Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
    +Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
    | Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
    Note: These links are hopefully temporary until we can sort out the excessive
    traffic on Repairfaq.org.
    Important: Anything sent to the email address in the message header is ignored.
    To contact me, please use the Feedback Form in the FAQs.
  2. Following up on my own post, I found the part - it's an Amphenol TW series
    connector. Now all I need to do is find a distributor.
  3. Jim Adney
    Jim Adney Guest
    I know I've even had catalogs for this in my hands, but I can't
    remember who makes them. I believe they are all customs, but I might
    be wrong about that.
    Googling for d-sub coax got me lots of hits. Finding the place that
    will sell you a finite number will be the trick.
    Usually there is some kind of trademark on the connector half that you
    have that would get you moving in the right direction.
  4. Pathogen
    Pathogen Guest
    try Mouser, MCM, delbania, or go to a Ham show (radio Op'ers)
  5. Tom Becker
    Tom Becker Guest
    This might be Cannon's DAMC3H3PJK87, Newark PN 93F8924
    Could be DBM5W5PK87, Newark PN 93F8910
    In the 70's, we used connectors of this sort for military-contract
    modems. As I recall, Amphenol and Cannon were the primary suppliers.
    There are many different pin styles and layouts, mixing small signal,
    power and coaxial (even fiber, today, I believe).
    Tom
  6. Tom Becker
    Tom Becker Guest
    In the 70's, we used connectors of this sort for military-contract modems.
    There are many different pin styles and layouts, mixing small signal, power
    Tom
  7. <snippety>
    You're describing ITT/Cannon parts, Sam. More specifically, their
    'Combo D' series. It's no surprise you couldn't find them in Jameco or
    Digi-Key, because they're all mil-spec parts.
    At the risk of some shameless self-promotion, I can get these for
    you in small quantities (I have no minimum order).
    http://www.bluefeathertech.com/connectors.html
    You may also be able to get them through Allied or Newark, but
    you're not likely to find them through any of the small distributors.
    That's a 7W2 pattern.
    That one's a 21WA4...
    That one's a 5W5.
    ITT designed these beasties to be very versatile. The large
    openings can accept either power or coaxial contacts. They do come in
    both solder-cup and crimp styles, however you should also be aware that
    the contacts in the solder-cup types are not removable.
    You should also know that, where the crimp style are concerned,
    there is a significant one-shot investment required for the appropriate
    hand tools for crimping and removal. Since these are mil-spec parts, the
    tooling needs to meet that spec as well, so you're looking at $250-$300.
    I can also supply the tooling, as can the dealers I've previously
    mentioned.
    Happy hunting. Drop me a line with specifics if you decide you
    want a quote.
    Dr. Anton T. Squeegee, Director, Dutch Surrealist Plumbing Institute.
    (Known to some as Bruce Lane, ARS KC7GR,
    kyrrin (a/t) bluefeathertech[d=o=t]calm -- www.bluefeathertech.com
    "If Salvador Dali had owned a computer, would it have been equipped
    with surreal ports?"
  8. These are close but not quite the same.
    But, I searched Newark and found the Amphenol connectors that are the same.
    Thanks.
  9. Thanks. Newark has them (actually the Amphenol connectors which are the
    exact match). If you can match their prices on qty. 2-5 of each of these,
    I go with you. :)
  10. I don't know that I can match Newark (they've got buying power I
    can only dream of), but I'll give it a shot. My local wholesaler is
    quite good with the D-subs.
    Hold that thought. I'll let you know on Monday.
    Keep the peace(es).
