C
Chris F.
Set is a '95 Zenith, forget the model but the CRT is an A68ACT00X. The
original CRT was completely shot, but I had another one in an old 1987
Zenith console. Remarkably, it was a perfect match. I thought I was in luck
to have found a replacement so easily, but I'd soon find out otherwise. Once
installed, it seemed to work fine - for a few minutes. Then the picture
turned into a super-bright greenish color with retrace lines. It only seems
to happen after the set warms up. Much troubleshooting later, it didn't seem
to look like any of the usual shorts (H-K, K-G1, etc). Then I got the idea
to pull the CRT board off while the set was running, after the problem
appeared. I was quite surprised to see a steady arc (not a spark) of about
1" jump from pin 11 (blue cathode) of the tube to the corresponding pin on
the socket. This only happened after the set had warmed up and problem
appeared, otherwise there was no arc. I powered the set again, waited until
it went bright greenish-white, and this time pulled the CRT board and
immediately stuck a HV meter probe to the area around pin 11. The meter
jumped to nearly 20kV, and stayed there for several seconds before slowly
fading away.
What kind of short is this anyway, and is there any chance it can be
removed?
In a perfect world, there would be no Zenith CRTs.......
Thanks for any advice.
fading away.
removed?
