G
George K
I have a circuit which takes the output of a one-shot and filter it.
There are two stages. First the signal goes to two parallel capacitors
between which there is a resistor, and one end of the resistor is
connected to the negative input of the amplifier and the other to the
output of the amplifier. The output of the amplifier through a
resistance goes to a similar network with a second op-amp which output
is the final output. The positive inputs of both op-amps are connected
through a voltage divider to Vcc/2.
To make it more clear I will number the components and I will describe
one stage of the filter as the second is the same. C1 1,p2 - C2:
p1,p3 - R1: p2, p3 - Op.amp. + : Vcc/2 - Op-amp - : p3 -
Op.amp out : p2.
R2 = resistor between the two stages : p2, p1' (=p1 of the second
stage)
And now what is going on and I cannot understand. I have two almost
identical prototypes of this circuit. In one of them the points p1',
p2', p3' have a Vcc/2=2.5V voltage and in the other circuit for the
same points there is a Dc component of Vcc/2 but there is a sinwave of
2V p-p added to the DC voltage. In the circuit with the aforementioned
AC voltage, the voltage before the resistor which is placed between the
two stages is only the DC component.
Op.amp out : p2.
stage)
