S
Sam Goldwasser
Now here's one you don't see everyday.
I have a taut band (I believe) D'Arsonval meter movement with a
plastic faceplate that seems to have areas of permanently static charge.
So, the needle gets stuck or gets pulled or pushed toward or away from
certain positions. I've removed the faceplate and it then works normally.
Moving the faceplate near the needle results in the needle changing
position. I've tried the usual approaches to getting rid of static but
it always comes back.
Assuming anyone has seen this before, is there any solution other than
replacing the faceplate? Is there such a thing as "degaussing" for
electrostatic charges? Destatic-ing?
I'd rather not have to fabricate a replacement.
Thanks.
--- sam | Sci.Electronics.Repair FAQ Home Page: http://www.repairfaq.org/
| Mirror Site Info: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: The email address in this message header may no longer work. To
contact me, please use the feedback form on the S.E.R FAQ Web sites.
Thanks.
