Strain gauge purchase
Discussion in 'Datasheets, Manuals and Component Identification' started by oldfart, Jul 24, 2017.
  1. oldfart
    oldfart
    10
    Jul 24, 2017
    I am a retired mechanical engineer and am interested in making a few projects involving strain gauges. These projects are primarily for personal learning. I have been trying to find a supplier of strain gauges at a reasonable cost. I can find some expensive ones from Digikey and a couple other places and found some cheap ones from AliExpress. The problem with the what I found from AliExpress is I can't find any datasheets about them and all the info is only in Chinese. Can you please help me find a place to buy strain gauges at a reasonable cost?
  2. kellys_eye
    kellys_eye
    4,275
    1,146
    Jun 25, 2010
    Personally I'd purchase a few cheap bathroom weigh scales and salvage the strain gauges (and electronics) from them.
    I have one set already (with older LED readout) that I originally intended to re-purpose to weigh propane tanks to indicate content.
    Another one of those 'when I get around to it' projects....
    Tha fios agaibh likes this.
  3. oldfart
    oldfart
    10
    Jul 24, 2017
    Thanks for the tip. My plan was to get some strain gauges and first put them on a simple beam to work out electronics etc. then I want to put some on a more complicated structure to measure strain (stress) at a few locations. Bathroom scales may work for a load cell type set up but I don't think it would help in my case. Anybody know a place to buy plain gauges with or without leads? A rosette would be even better.
  4. kellys_eye
    kellys_eye
    4,275
    1,146
    Jun 25, 2010
    RS Components do some basic gauges ranging in price from $10-$20 - not particularly expensive and guaranteed to come with a data sheet. It should provide you with enough information to get started but I don't think sensors more complicated than the 'basic' versions will come 'cheap' no matter where you go for them.
  5. Minder
    Minder
    3,029
    641
    Apr 24, 2015
    I have bought off ebay for a couple of $$'s also load cells very cheap ($1.50).
    M.
  6. kellys_eye
    kellys_eye
    4,275
    1,146
    Jun 25, 2010
    The OP is aware of such but lacks the data sheet information - a common problem with cheap'n'cheerful purchases from China.
  7. Minder
    Minder
    3,029
    641
    Apr 24, 2015
    Well for a $1.50 not much is lost, for a $s couple more you get an amp attached ebay 182409854910
    There is usually 4 connections, two excitation and 2 output.
    The info is sometimes vague but the same principle is pretty much the same across the board.
    And after a little empirical testing, the general operation comes clear.
    M.
  8. oldfart
    oldfart
    10
    Jul 24, 2017
    Thanks for your help guys... I appreciate it.
Similar Threads
Loading...
