STM32f407 board 5V pulse with 40kHz frequency
Discussion in 'Microcontrollers, Programming and IoT' started by victorrr, Mar 20, 2015.
  1. victorrr
    victorrr
    11
    Feb 11, 2015
    Hi! I modified the following program to get a pulse of 5V and 40kHz of frequency. I tried it in an oscilloscope and I get a 4V pulse and 12,8kHz frequency. What is wrong in the code??
    Code:
    #include "stm32f4xx.h"
    #include "stm32f4xx_rcc.h"
    #include "stm32f4xx_gpio.h"
    #include "stm32f4xx_tim.h"
    void TM_LEDS_Init(void) {
        GPIO_InitTypeDef GPIO_InitStruct;
        /* Clock for GPIOA */
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
        /* Alternating functions for pins */
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_TIM13);
        /* Set pins */
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6;
        GPIO_InitStruct.GPIO_OType = GPIO_OType_OD;
        GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStruct.GPIO_Speed = GPIO_Speed_100MHz;
        GPIO_Init(GPIOA, &GPIO_InitStruct);
    void TM_TIMER_Init(void) {
        TIM_TimeBaseInitTypeDef TIM_BaseStruct;
        /* Enable clock for TIM13 */
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM13, ENABLE);
        Set timer prescaler
        Timer count frequency is set with
        timer_tick_frequency = Timer_default_frequency / (prescaller_set + 1)
        In our case, we want a max frequency for timer, so we set prescaller to 0
        And our timer will have tick frequency
        timer_tick_frequency = 84000000 / (0 + 1) = 84000000
        TIM_BaseStruct.TIM_Prescaler = 0;
        /* Count up */
        TIM_BaseStruct.TIM_CounterMode = TIM_CounterMode_Up;
        Set timer period when it have reset
        First you have to know max value for timer
        In our case it is 16bit = 65535
        To get your frequency for PWM, equation is simple
        PWM_frequency = timer_tick_frequency / (TIM_Period + 1)
        If you know your PWM frequency you want to have timer period set correct
        TIM_Period = timer_tick_frequency / PWM_frequency - 1
        In our case, for 40Khz PWM_frequency, set Period to
        TIM_Period = 84000000 / 40000 - 1 = 2099
        If you get TIM_Period larger than max timer value (in our case 65535),
        you have to choose larger prescaler and slow down timer tick frequency
        TIM_BaseStruct.TIM_Period = 2099; /* 10kHz PWM */
        TIM_BaseStruct.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_BaseStruct.TIM_RepetitionCounter = 0;
        /* Initialize TIM13 */
        TIM_TimeBaseInit(TIM13, &TIM_BaseStruct);
        /* Start count on TIM13 */
        TIM_Cmd(TIM13, ENABLE);
    void TM_PWM_Init(void) {
        TIM_OCInitTypeDef TIM_OCStruct;
        /* Common settings */
        /* PWM mode 2 = Clear on compare match */
        /* PWM mode 1 = Set on compare match */
        TIM_OCStruct.TIM_OCMode = TIM_OCMode_PWM2;
        TIM_OCStruct.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCStruct.TIM_OCPolarity = TIM_OCPolarity_Low;
        To get proper duty cycle, you have simple equation
        pulse_length = ((TIM_Period + 1) * DutyCycle) / 100 - 1
        where DutyCycle is in percent, between 0 and 100%
        50% duty cycle:     pulse_length = ((2099 + 1) * 50) / 100 - 1 = 1049
        Remember: if pulse_length is larger than TIM_Period, you will have output HIGH all the time
        TIM_OCStruct.TIM_Pulse = 1049; /* 50% duty cycle */
        TIM_OC1Init(TIM13, &TIM_OCStruct);
        TIM_OC1PreloadConfig(TIM13, TIM_OCPreload_Enable);
    int main(void) {
        /* Initialize system */
        SystemInit();
        /* Init leds */
        TM_LEDS_Init();
        /* Init timer */
        TM_TIMER_Init();
        /* Init PWM */
        TM_PWM_Init();
        while (1) {
    Thank you
  2. victorrr
    victorrr
    11
    Feb 11, 2015
    Problem solved
    davenn likes this.
