Stereo Receivers dead after power surge but all fuses intact
Discussion in 'Electronic Basics' started by Mienie, Dec 27, 2003.
  1. Mienie
    Mienie Guest
    I have two stereo recievers that are dead after a power spike
    (high-low on the pole on the corner of my block). I was hoping that it
    would be a simple matter of replacing a blown fuse, however, when I
    opened them up the fuses were fine. Both the one near the AC cord and
    those on the transformer.
    Any ideas on what the problem is or where I should start looking? I
    have a multimeter though I'm just getting up to speed on how to use
    it--and basic electronics! ;-)
    The receivers are a Pioneer VSX-454 and a Sony STR-D605. Looking
    around for cheap replacements reveals that low-end receivers no longer
    have phono inputs and this is a feature I often use so I'm definitely
    looking to fix these.
  2. Ross Mac
    Ross Mac Guest
    Try sci.electronics.repair......
  3. Mienie
    Mienie Guest
    Shall do. Sorry to be off topic.
  4. Ross Mac
    Ross Mac Guest
    Hey, there's a lot of sharp guys here too that may be able to help you, but
    that newsgroup specializes in consumer electronics...Good Luck, Ross
  5. Art
    Art Guest
    Ross, initial thing would be to check for the fuse devices, which you have
    done. Then check the resistance of the power input transformer primary for
    open, apply voltage and check secondary derived voltages. Then follow the
    rectified paths to the other circuits. Again: safety is the first concern.
    Also do post to "ele*repair" as suggested.
  6. Ross Mac
    Ross Mac Guest
    Art....I didn't post this one...I just sent the poster to the consumer
    group....take care, Ross
  7. Mienie
    Mienie Guest
    thanks.
  8. Grumpy OM
    Grumpy OM Guest
    Mienie,
    How do you know there was a surge? Was it caused by a direct
    lightning strike on the pole? Were both receivers turned on at the
    time? Silly question, but have you checked for voltage at the outlet?
    I've had lightning strkes on my lines, but the only part of the
    receiver that fails is the tuner.
    Grumpy
  9. Guest
    About 20 years ago I had a stereo system in an apartment with very unstable
    floors that would easily kick the turntable needle out of the groove (this
    was about when CDs came out, so most of my collection was still on vinyl).
    My solution to that was to relocate the system to another room and pull the
    speakers into the living room. The speaker runs were about 20 meters so I
    got some very big thick monster cable for it. All went well.
    Later I decided to move the stereo upstairs and create a "listening room"
    out of a spare bedroom (the largest one in fact). Now I only needed about
    2.5 meters of run to the speakers. Not wanting to cut up that precious
    speaker cable (I might decide to move things back downstairs later on), I
    just coiled up the excess into a closet that was conveniently between the
    amplifier and the speakers.
    I religiously unplugged everything from the power mains, especially making
    sure during thunderstorms. But that didn't stop a nearby lightning strike
    killing the system. All the amplifier PA transistors were toast. The bass
    speakers survived, but the tweeter coils were vaporized! I assume it was
    the high frequency impulse induced on the coiled speaker cables. Repairs
    cost about $400. Had I just bought some new shorter speaker cables that
    didn't need to be so thick, it would have been about $20 (though it still
    could induce some voltage on some length of wiring).
  10. Grumpy OM
    Grumpy OM Guest
    Phil,
    That's a good anecdote, and why I asked for more specifics. When
    lightning hit my electric pole it blew my external modem. There was a
    crater in the center of the board where a chip had been. The spark by
    passed all of the filters. Those cables of yours made a great loop
    antenna.
    Grumpy
