Stepping down speaker input to line level
Discussion in 'General Electronics Discussion' started by PMSM, Aug 21, 2016.
  1. PMSM
    PMSM
    4
    Aug 12, 2016
    Long time solderer, first time circuit designer. I've got an electronic billboard has two speakers, which according to the spec sheet are 5 watts, 8 ohms, and I want to reroute the signal from them to a 3.5 mm jack, that I'm going to plug into some 10 ohm computer speakers.
    What intermediary changes do I need to make to the signal so none of the equipment is damaged? The audio file the billboard plays is mono, so should I bother wiring both speakers inputs into the new speakers? If not, is it safe just to throw an 8Ohm resistor on the side I'm not using? What else should I look out for?
    Thanks in advance
    -D
  2. Alec_t
    Alec_t
    3,000
    813
    Jul 7, 2015
    Are these powered and amplified speakers, or just naked speakers?
  3. PMSM
    PMSM
    4
    Aug 12, 2016
    Powered and amplified. Edifier mp230s, to be specific.
  4. BobK
    7,682
    1,688
    Line level is about 1/2V peak. Your 5W speakers are about 6V peak. So I would reduce the voltage with a voltage divider by a factor of 10 or so. I.e. 10K to the output 1K to ground, junction to the input.
    CDRIVE likes this.
  5. PMSM
    PMSM
    4
    Aug 12, 2016
    Excellent, I'll definitely do that. Thank you Bob!
  6. CDRIVE
    4,960
    652
    May 8, 2012
    Gee Bob, I think you could have complicated this just a tad. After all if they were all this easy we'd have nothing to do here!:)
    Chris
  7. BobK
    7,682
    1,688
    You are right Chris. I think maybe an 8 pole active bandpass filter using 4 Salen-Keys stages is required. Chebyshev response of course.
    CDRIVE likes this.
