Stepping code
Discussion in 'Microcontrollers, Programming and IoT' started by shady, May 23, 2017.
  1. shady
    shady
    43
    5
    Aug 3, 2013
    I was just looking for a replacement MCU, namely SAK-C167CS-LM CA+. I know the variation SAK, SAF and SAB has to do with the temperature the MCU can handle, however, I've seen different stepping codes like CA+ and H+, what do these variation mean?
  2. Harald Kapp
    11,513
    2,651
    As far as I can see there is no h+ stepping of the SAK-C167CS-LM CA+ (no SAK-C167CS-LM H+ on the Infineon website).
    There is, however, a SAB-C167SR-LM HA+.
    I'm not familiar wit these controllers so I can't tell you about the differences, Check the datasheet for them.
    Different steppings of the same type of chip usually are required for error correction. It is next to impossible to get a complex chip fully correct with the first stepping. Think of the "steppings" as redesigns. The higher stepping is normally the better one (less errors) - exceptions confirming the rule ;)
    shady likes this.
  3. shady
    shady
    43
    5
    Aug 3, 2013
    Thanks Harald that helped a lot. My mistake i was suppose to write HA+ and not H+. I did speak to Infineon via online support, she explained about the prefix, which I was aware of, however, she didn't know about the stepping code.
    If i wanted to replace an MCU with stepping code CA+ with a HA+ it shouldn't make any difference but only would produce less errors?
  4. Harald Kapp
    11,513
    2,651
    Presumably yes.
    TYpically you'd find the differences in the processor's errata sheet, but there seems to be nonen for this controller. It is likely that in that case the fixes are minor and may not even be obvious to the user (e.g. if the new stepping was made to enhance the yield of the manufacturer).
