jackorocko
- Apr 4, 2010
- 1,284
- Joined
- Apr 4, 2010
- Messages
- 1,284
I have been pondering on what type of stepper motors to buy for a project I have been putting together for the past couple of months. I found this website http://www.kelinginc.net/SMotorstock.html which has a ton of motors at what seems like reasonable prices. But I am a little confused on a few points.
At the top of the website it says in bold red letters, The Max. applied Voltage can be up to 20-25 times of Rated Voltage ***. What exactly does this mean and what does it mean exactly when the motors are listed with a voltage rating? Most of the motors on that website work with a rated voltage of < 12V. I thought I read somewhere that the more voltage applied to a stepper the faster the rpm's. Since motors are just big inductors, I assume that if I up the voltage then the current required would also reduce since the resistance of the coil won't change, but what about its reactance? I have always been rather thick headed when it comes to inductors and motors so if someone could clear the air a little I would appreciate it. My main concern is I bought a few drivers for the steppers and they have a max of 2.5A, most of the motors on that website are easily over that rating. The way the driver documentation puts it, 5A and up to 55VDC should handle any motor on the market up to NEMA 34
