Stepper motor PID control
Discussion in 'Electronic Design' started by [email protected], Aug 29, 2007.
  1. Guest
    Sorry.. I've forgotten this question in previous message: It's
    possible to control a stepper motor in a closed loop system via a
    common PID algorithm ? I ask this to you because many commercial
    controllers that I've found have encoder input but use it only for
    stall detection. I think a continuous controlling of stepper motor
    isn't a great idea due to discreet nature and relative low resulution
    of stepper motors: I think that is sufficient an accidental little
    movement of mechanical system respect to idle position to cause
    continuous vibrations: is it correct ? My idea is to use PID only
    during motion commands and stop it when axis is settled in a given
    range: it will limits axis overshoot and precise positioning without
    undesidered steady vibrations.
    What do you think about.
    Best regards.
    Simone Navari.
  2. BobG
    BobG Guest
    Pretend its a DC sin/cos torquer and drive it with a variable
    frequency sin/cos drive?
  3. whit3rd
    whit3rd Guest
    Yes, in a way. You can make an error signal with PID techniques, feed
    it to a VFC (voltage-frequency converter-I like CD4046 for this
    application)
    and use pulses from the VFC to clock your stepper drive. Two VFCs and/
    or
    a bit of logic can make it work in reverse as well as forward.
    The discontinuity at a step will, however, drive the 'D' term of your
    PID
    somewhat crazy. PID control is better suited to DC servomotors.
