stepper motor control
Discussion in 'Sensors and Actuators' started by bbrummett, Mar 7, 2013.
  1. bbrummett
    bbrummett
    Mar 7, 2013
    Hello recommendations-
    The task at hand with the question:
    Control a bipolar stepper motor Imax=1.8A, Resolution is .45deg, V=24vdc
    The question is what type of microprocessor?
    inputs to decide the control of the stepper are:
    1. Variable frequency square wave
    2. Feedback from the steppers pot for angle reference
    3. 2 signal inputs for shut off safety
    outputs
    1. Of course signal to driver ckt for stepper
    2. Driver for a relay coil 300mA max.. can build external I carrier
    The micro should be able to rewrite program. The stepper will only sweep +90deg back to 0 deg. I think max 0 to 90deg in about 250mS
    I would like to use a pic 16f88.
    Any experience/knowledge/ideas with this would be helpful. Thanks
  2. BobK
    7,682
    1,688
    A 16F88 should be able to handle it.
