E
Erik Archer
Hello,
I have a Modine gas Heater in my garage on a dedicated 110v/15A
circuit. (USA 60 Hz)
When the Thermostat is off, I can here a distinct hum from the main
power transformer in the unit. (110v to 24v Step down).
(It appears to be a 4" iron square, mounted directly/enclosed within
the metal casing of the heater. 2 wire 110v in, 2 wire 24v out).
It is not a loud hum by any stretch, you could only hear it if you
stand quietly by the unit.
My question is, is the hum ok / normal?
(The heater itself is 4 years old and ran every winter, the previous
owner said it did not hum, but I doubt he would have noticed
this hum, or even paid attention to it).
I googled archived groups and similar questions about hum have
been asked, with just about any answer you could imagine.
Some posts say replacement, others say it is normal, problem is
most are directly related to A/V equipment and I don't know that
garage heaters fall within such a exacting specification.
Other posts said to remount/isolate the transformer from it's current
mounting to help isolate transmitted vibrations.
My question then being, if I remounted it, should it/what if, it is
insolated from the heater chassis? Ok?
Others mentioned dirty AC line voltage, but the garage construction
is new, and the rest of the electronic equipment in the house has
shown no indication of poor/dirty power.
Suggestions appreciated.
-Erik
-Erik
