stepdown dc/dc power
Discussion in 'Electronic Basics' started by peter, Aug 25, 2004.
  1. peter
    peter Guest
    Hello all
    Just have a techniacl question. Over the passed 2 days I'm trying to
    think of a way to build a power suppyly for may magellan sportrak
    map(gps) which needs 3.8vdc-4.2vdc that will be converted from cars
    12vdc. What is the best way to put that power supply togther ueseing
    easy to find.
    Thanks in adcance.
  2. Look up the LM317, that is an adjustable voltage regulator just made for YOU
    :). Very simple circuit to do what you want, with a bit of ingenuity it
    should be able to fit it inside a generous cigarette holder plug.
  3. CFoley1064
    CFoley1064 Guest
    Subject: Re: stepdown dc/dc power
    ____
    + IN| |OUT +
    o----o----| 317|----o------o------o LM317T (Front View)
    | |____| | | .---------.
    | ADJ| .-. | | |
    | | 240| | | | o |
    .1uF|+ | | | 1uF|+ | |
    12V | o-------' | 4.2V | |
    | | |560 | | | |
    o----o------o--------------o------o A O I
    D U N
    J T
    created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
    Good luck
    Chris
  4. Rich Grise
    Rich Grise Guest
    You don't say what country you're in, but RS has various car lighter
    adapters with the regulator already in them, I'm pretty sure.
    Good Luck!
    Rich
  5. JeB
    JeB Guest
    adaptors which provide up to 1 amp at a wide selection of voltages and
    with an assortment of plug adaptors are very affordable.
  6. peter
    peter Guest
    Did not have chance to read the post, but I found some time now.
    Thanks to all. This is a great solution opposed to buying a $199.00
    cable from a store and I believe you answered many purple's question.
    Thanks again
