step up converter
Discussion in 'Electronic Basics' started by lerameur, May 28, 2007.
  1. lerameur
    lerameur Guest
    Hello,
    I am building a step converter, the circuit works and is based on the
    following web site:
    http://services.eng.uts.edu.au/~venkat/pe_html/ch07s3/ch07s3p1.htm
    My circuit boost from 5v to 150v, bit it takes about 45 seconds to
    reach the maximum voltage with the proper duty cycle. I found out by
    using a bigger coil I get a faster result. Is there a way to reach the
    150v within 10 seconds or less? or is this how it usually works and we
    cannot do anything about it..
    ken
  2. Charles
    Charles Guest
    Use a push-pull converter configuration for a much faster response time.
    http://schmidt-walter.fbe.fh-darmstadt.de/snt/snt_eng/snteng4a.pdf
  3. lerameur
    lerameur Guest
  4. Guest
    Strewth!. I didn't think these things could get that horribly
    complicated. Any chance of you posting somewhere your actual circuit?.
  5. lerameur
    lerameur Guest
    Figure 1 on the link above.
    with a 2n3055 and a 3300UF 350v elec. cap, no resistor at the load.
    That simple. The coil I wound myself with 300 feet of magnetic wire.
    ken
  6. Guest
    (at some point you'll need to know your inductor value)
    You've complete control over how fast the capacitor charges up.
    At 150V your capacitor stores a whopping 40 Joules of energy. A one
    second recharge time could be actioned by storing 40J in the inductor
    and switching across once per second (an impractical 0.3H and 17amps).
    Or storing 4mJ and switching across 10000 times a second. A 10 second
    recharge would get you down to a more reasonable couple of amps.
    Joules energy stored in the inductor is equal to 1/2 x L x current^2.
    (it's the inductor 'peak' 'current at the point where the transistor
    is switched OFF, that counts.)
    Basically it's how many amps you can get through the inductor when the
    transistor is ON and the number of charging/switching cycles you can
    put up with each second.
    More power implies a lower inductor value as ...
    Amps per second rise through inductor = Voltage across inductor / L.
    I.e low L values allow a high current (hence energy) build up in a
    short time.
    Somewhere there is a happy balance. You've got to look for the sweet
    spot.
    With the 300' of wire and old 2N3055 transistor, your lazy charge
    problem could be down to voltage loss across the ON transistor and
    high wire resistance.
    You've only 5V to play with and at the needed couple of amps or so, an
    odd volt and a few ohms means the inductor sees only a fraction of the
    full voltage and the design is lost.
  7. lerameur
    lerameur Guest
    I did tried different inductor values, I actually get better
    performance using a higher value coil.
    In one case i used a 12v supply battery and a 220uF inductor (Dn4516-
    ND at digikey). I get increment just about the same as before. With a
    high value inductor, the current might be less, but the potential peak
    is higher.
    Ken
  8. Guest
    The lower the coil resistance the better. A high R value can quite
    easily dominate the circuit performance. Dependant on quality you can
    have a higher inductance but lower R. Commercial inductor makers
    strive constantly to reduce their R values.
    I can't believe what I've just gone and done but have downloaded and
    actually read a 2N3055 datasheet. :).
    Looks like you'll be losing 1V across it when the inductor is charging
    but more to the point, you'll need to be driving the base with
    something like 1/2 amp, which is a biblical quantity of current .
    Would suggest it's far, far better to get hold of a cheap power FET
    instead. You'll get that volt back and have far simpler switching
    needs.
  9. lerameur
    lerameur Guest
    I have been driving the 2N3055 with a microcontroller, its far from
    driving 0.5 amp and it works. I am also looking into driving a high
    speed step up transformer. I cannot even find that at digikey. Is it
    me or does somebody knows a part number at digikey ?
    ken
