A
Andy K
I have a single LED that I would like to use as a visual indicator that my phone is ringing.
It came off a string for a store display that used either a 9V or a few AA batteries.
Voltage to be reduced is around 40 volts D.C.
Hooking up to a red 12 volt "instrument type light" brought the voltage down to about 10 volts if that helps. And the bulb still works, but phone gets static.
What would it take to step down the voltage so I can use the bulb ?
It's been a lot of years, but I think I remember needing a zener diode or two and some resistors.
Thanks.
Thanks.
