Stellaris JTAG problem
Discussion in 'Electronic Design' started by Marco Trapanese, Mar 11, 2012.
  1. Hello,
    I have several boards that host LM3S* Stellaris MCU. They are different
    boards but the connections around the MCUs are the same.
    Some boards work fine and I can program the MCU using JTAG (LMI FTDI).
    Others don't work - LM Flash Programmer returns error while connecting.
    I might exclude a design error due to the working boards. Perhaps some
    problems during soldering.
    I checked:
    - power supply on MCU pins
    - RST and TRST pull-ups on MCU pins
    - JTAG connection (and pull-ups) between MCU pins and JTAG programmer
    - WAKE, CMOD0, CMOD1 logic levels on MCU pins
    What would you do further to find out the cause of the problem? I'm
    wondering about other measures or test I can do.
    Thanks!
    Marco
