M
Mark Harriss
I bought a 40W soldering iron for $4.95 at Crazy
Clark's for a temporary soldering job. It was a
bit too hot which is what you'd expect at 40 Watts
with a tip the same size as a 25 Watt iron but the
real fly in the ointment was the silver coloured
tip that turned out to be unplated: within a few
minutes it was already pitted and looking crook
with the solder being burnt by the extra heat.
I found some spring steel rod the same
diameter and ground a cone tip on the bench grinder
by spinning the steel in the battery drill. After
fitting to the soldering iron it runs great: the
lower conductivity of the iron tip cuts the heat
nicely and doesn't overheat the solder at all, the
tip manages to solder fine and only bogs down on
a massive join as you'd expect with the lower
thermal conductivity. All in all it made an
unusable iron into quite a good one.
I'll have to try some other irons I have
that need tips that I can't get locally. Dicky's
doesn't seem to have tips for their budget irons
although the one that might fit, with a shoulder
machined on it, is $6.95 or half the cost of a
budget iron.
budget iron.
