A
Al Dykes
The web page descriptions are indeed fairly funny, if you know
what they are talking about. But I highly suspect anyone with a
limited background in Electro Static Discharge will be more
confused than not.
Yep. Quite a lot.
*Moving* *dry* *air* around is a great way to build up a static
charge on any component that is an insulator.
Hence *compressed* *dry* *air* and *vacuum* *cleaners* are not
good ideas. In fact, compressed air might be worse because it
can forcefully blast dust into places it wouldn't otherwise go.
If you get enough charge (a few thousand volts, for example, is
common), it will then break down the insulation between the
charge and the next nearest object that is either also holding a
charge or is able to dissipate the charge (e.g., a conductor).
The current flow when that happens is what kills your computer.
And it isn't just that specific current, but also any current
induced into other conductors as a result of that current.
The way to get the dust out of a computer case safely is to use
a damp rag to manually pick up dust. It shouldn't be so wet
that it drips moisture (though that isn't necessarily bad
either, see below), but needs to be damp enough that dust will
stick to it and static cannot build up on it. I personally
prefer to have a large bowl of water mixed with a little
household cleaner (such as 409 or Mr. Clean), in which the dust
rag (a well worn bathroom wash cloth or a thin dish towel, is
nice) is washed as it get dirty. The soapy water in the bowl
should be changed somewhat regularly too, i.e. when it gets so
dirty that as much dirt moves from the water to the rag as from
the rag to the water!
Which type of soap to use does make a difference. The idea is
something that will dissolve any grease film or other coating
that might be present, but even more important is that it be a
good water dispersant. Automatic dishwater soap is perhaps the
best in that respect.
I've worked with professional disaster cleanup crews that use
deionized distilled water with a pressure washer, set at modest
pressure. Nothing added. Immediatly after the component is hosed off
they pop the item is a standard commercial convection oven set to
about 160F for a few minutes.
As a practical matter, I see no problem with cans of compressed gas.
Use a wrist strap if the equimpment is made of unreplacableium.
