D
[email protected]
how to effectively put an analog-meter's clear plastic cover at dc
ground, to prevent buildup of static charge?
Frank said:Replace the movement with a digital readout.
Jerry Avins said:How will that help?
How will that help?
In Lieu of sprays & wet stuff--get one of those fabric-softner paperhow to effectively put an analog-meter's clear plastic cover at dc
ONLY A HOMOSEXUAL WOULD WORRY ABOUT BUILD UP OF STATIC CHARGE
DON'T LET THE DOOR HIT YOUR ASS ON THE WAY OUT NOT THAT YOU WOULDN'TJim said:What a scumbag. Bye.
...Jim Thompson
I do not think that grounding the screen, non conductive to the dc ground is
going to help.
but I have been wrong before.
Hi !how to effectively put an analog-meter's clear plastic cover at dc
Commercially this is done with a very thin metallic film over the
plastic... so thin that it's not visible.
I don't know if there's a DIY way to do it.
Jim Thompson said:Commercially this is done with a very thin metallic film over the
...Jim Thompson
Carbon works best for this particular problem but can't be SputteredRisto said:Hi !
Visit the nearest university where is an electron microscope.
They have sputter devices to cover EM samples with a thin gold, silver
or carbon layer.
Maybe you can motivate them to sputter your meter front plate with a
thin and practically invisible gold layer .
Ask them to sputter the inside of the plate.
They have also silver paint for SEM samples
You need to paint a narrow conductor outside from this sputtered inner
surface to ground the sputtered area.
Best to paint a conductor to all 4 corners
Once I sputtered a table tennisball with gold. The idea was to make a
very light corona hat for a low band wire vertical lifted by helium
balloon
73, Risto OH2BT
