static electricity generators
Discussion in 'General Electronics Discussion' started by ratstar, Mar 1, 2021.
  1. ratstar
    ratstar
    486
    20
    Aug 20, 2018
    This video has some cool static electricity generators.
    But I'm not quite sure how to put them together myself, I'm not sure about what materials to use, but especially I don't know how to connect the anode and cathode.
    Any help from anyone would be gratefully appreciated.
  2. bertus
    bertus Moderator
    2,262
    840
    Nov 8, 2019
    Hello,
    Did you see his other video:
    The power will be very minimal.
    Bertus
    ratstar likes this.
  3. ratstar
    ratstar
    486
    20
    Aug 20, 2018
    Ah thanks I missed it!
    But I've got a slightly different question, you know how dc motors are also generators. is the same true for capacitors? (Electrostatic actuators as generators) That if you dolly the plates back and forth mechanically do you get a charge coming out of it?
  4. bertus
    bertus Moderator
    2,262
    840
    Nov 8, 2019
    ratstar likes this.
  5. bertus
    bertus Moderator
    2,262
    840
    Nov 8, 2019
    Food for thought:
    ratstar likes this.
  6. Harald Kapp
    11,967
    2,800
    No.
    ratstar likes this.
  7. ratstar
    ratstar
    486
    20
    Aug 20, 2018
    Heres another friction generator, looks cool, has a slide style and a contact style.
  8. Harald Kapp
    11,967
    2,800
    Read it yourself. The relevant statement is this:
    Therefore this setup does not provide charge by simply moving the plates back and forth as you stated in post #3. An initial charge has to be provided externally and is then used to increase the voltage by changing the dielectric constant of the medium between the plates.
    ratstar likes this.
  9. ratstar
    ratstar
    486
    20
    Aug 20, 2018
    I wonder what wins out of doing it with a capacitor, or doing it tribo-electric, contact mode.
    That contact style looks cool. it would be similar to doing it with a capacitor, because u would set up a heap of parallel plates the same, it could look a very similar machine.
    heres another vid on the contact, "tap" style generator.
  10. Nanren888
    Nanren888
    558
    165
    Nov 8, 2015
  11. Nanren888
    Nanren888
    558
    165
    Nov 8, 2015
    For small Van de Graffs is often mechanical friction at the source, on the belt, then accumulation of charge (with fixed capacitance: ball to ground) ==> voltage increase.
    There are many traditional machines that used static.
    Google Whimshurst machine?
    https://en.wikipedia.org/wiki/Wimshurst_machine
    Have you seen the one where two flows of water fall through rings, breaking into droplets & spontaneously charging the vessels?
    https://en.wikipedia.org/wiki/Kelvin_water_dropper
    Generator? No.
    As in something that converts mechanical energy to electrical?
    Also there is an old experiment where you join & separate charges metal balls.
    Basically after charging the plates of a capacitor, if you increase the separation of them the capacitance goes down, so for a fixed charge the voltage goes up.
    You can also induce charges on adjacent pairs of spheres (touching each other), then separate the pair, so you have effectively charged a capacitor. You put mechanical energy into the system when you separate them from the inducing static charge, or each other: that is opposing the attractive force of the electrical charges. Check out a physics book on static electricity.
    Sorry, couldn't find a link just now.
    As above: generally negligible amounts of energy.
    Piezo, as in those devices that help you light your gas. Hit/deform the crystal, voltage results.
    https://www.americanpiezo.com/piezo-theory/generators.html
    Might also want to google energy harvesting, rectennas,
  12. Audioguru
    Audioguru
    3,480
    740
    Sep 24, 2016
    Hey RAT, aren't you in Down Under that is summer time now? Here it is freezing in winter (almost Spring) and the humidity is very low so the static electricity doesn't drain away quickly.
    ratstar likes this.
  13. ratstar
    ratstar
    486
    20
    Aug 20, 2018
    The *potential charge* or total store stays the same. as d increases v increases, as d decreases v decreases.
    as d decreases, capacitance goes up, while volts go down, (like u said...), so it cancels out no matter how far the plates are apart. :)
    AudoGuru - if you keep it in a sealed vessel, then its separated from humidity also.
