Hi all,
This is my first time on the site.
I sometimes get trouble with Crystals not starting up. I am making a new circuit, modifying a circuit where the Crystals always start up, but on the new circuit it doesn't. The Crystal (Watch type 32766 Hz) is connected to the input of a 4060 divider circuit, as the suggestion on the PDF. I have used the same components as the working cicuit. I found that when checking if the Crystal was working using an Oscilloscope on pin 10, it would start, then even just the Oscilloscope lead would start it. I made a 60mm length of screened lead, connected it to pin 10 and the screen to Gnd, it now works. Is it likely to be reliable?
Cheers, Camerart.
Cheers, Camerart.
