START/STOP Sync pattern
Discussion in 'Electronic Design' started by [email protected], Aug 9, 2005.
  1. Guest
    Hi all,
    I am implementing some logic in FPGA(Transmit/Reveive).
    On the receive data first i look for a 8- bit pattern to detect the
    START pattern.Now my question is in the data also i may get the same
    START pattern how to distinguish between the START /STOP pattern and
    data.
    Any comments are appreciated.
    Regards,
    Prav
  2. Mochuelo
    Mochuelo Guest
    If the receiver delivers bytes to the upper level, I recommend you to
    use escape sequences.
    For instance:
    Received Meaning
    00 00
    FC FC
    FD 0D FD
    FD 0E FE
    FD 0F FF
    FE Beg of packet
    FF End of packet
    Every time you receive 0xFE, you know you are at the beginning of
    packet. You cannot find 0xFE inside the message (assuming no errors).
    Similarly for 0xFF. Also, every time you receive 0xFD, you know you
    have hit a 2-byte escape sequence, and you need to read the next byte.
  3. Kryten
    Kryten Guest
    Okay, so now as well as avoiding one byte code in the data, you now have to
    avoid more than one.
    This has not improved the situation.
    8-bit data links have been invented.
    Don't re-invent them.
  4. Mochuelo
    Mochuelo Guest
    It makes synchronization -look at the thread title- more simple and
    robust, using a very simple mapping with a ridiculous overhead
    involved (1.2 % for long messages).
    I could make it to avoid only one byte code, but I chose it to avoid
    two to distinguish between beginning and end of packet. The benefit is
    clear and the overhead is just 0.4 %, so go for it.
    Like which one?
    Show me one with better ratio benefit/overhead, and with a similar
    implementation complexity.
  5. PeteS
    PeteS Guest
    Another very simple way to do this (in line with Mochuelo's technique)
    is to use a standard encoding (such as 8bit - 10bit encoding as used in
    various ethernet and other communications protocols) and then assign a
    comma code [sometimes known as a code violation] (precisely as is done
    in such links) for start / stop.
    This adds overhead, of course, but unless you want to get into
    statistical analysis (such as framing bits require), it's simple, uses
    a published standard and cheap in hardware to implement.
    Cheers
    PeteS
  6. Kryten
    Kryten Guest
    HDLC
  7. Mochuelo
    Mochuelo Guest
    HDLC is not 8-bit oriented. It is 1-bit oriented. Implementing bit
    stuffing when you work one byte at a time is possible, but also a pain
    in the ass (I did it once). Nothing to do with the simplicity of the
    mapping I mentioned. I should remind that the first sentence of my
    first post was "If the receiver delivers bytes to the upper level."
