Stacking mosfets
A
Arpit
Hi, a design calls for some mosfets rated at about 20 amps and 500
volts IRFP460 to be precice. But the mosfets I have access to only are
rated at 200 volts, though have a substantial amperage rating. WOuld
it be possible to stack them somehow in series or something to
increase the effective voltage rating of the whole bunch?
M
Mike Harding
In a word; No.
500V is a serious voltage, unless you _really_ know
what you are doing use the specified parts and don't
mess with the design.
What are you making?
Mike Harding
A
Arpit
In a word; No.
It'll probably only run off 315 volts or so, ie 240 volts rectified,
and im used to that, thanks for the concern tho , makes me feel wanted
P
Phil Allison
Mike Harding said:
In a word; No.
** Arpit is a 16 year old.
............ Phil
V
Victor Lamb
So? What is your point? Many of us got into electronics when we were young.
All the more reason to provide information and assistance to this person.
It's better that they got the benefit of the experience of the people here,
rather than put themselves at risk of injury, shock or causing damage to
equipment.
If I knew something about the use of MOSFET's in power applications, then I
would tell Arpit something useful. Unfortunately I don't.
Vic.
P
Phil Allison
** The danger to him.
** You must be a absolute idiot.
equipment.
** Huh ?
You are worse than I tought.
** Thank god for that.
............ Phil
M
Mike Harding
Oh god, I knew I shouldnt have let slip my age. Ah well, I guess you
are only saying it out of concern for me :)
To be fair to Phil I think that was exactly his reasoning.
And he's right.
That circuit is intended to run from 120V AC, if you
connect it to 240V the voltage between "+350v"
and "Power" will be closer to 700V! So you had
better think carefully about the voltage ratings of
BR2 and C15/C16. Not to mention all the other
HV stuff on the secondary of T2 - and you'll need
to upgrade (not downgrade) those MOSFETs.
And keep in mind that with C15/C16 at 4700uF
and 700V touching those is probably instant death.
Arpit I fully understand the attraction of these sorts
of circuits to you (we've all been there) but messing
with that sort of stuff when you don't understand
it may well kill you. Leave the high voltage stuff
alone for now you need a lot more knowledge
before you can work with it safely.
Mike Harding
A
Arpit
And he's right.
Yeah, I saw that, I'm just gonna run it off off my capacitor bank i
made a couple of months ago- about 1500uf at 315 volts.
What are some good books about the subject?
T
The real Andy
Or do this (be careful), please exuse crude drawing and please heed all
warning others have given, such as please do not attempt this at home - use
it as a reference only.
bridge
Live -----------/\ +----+------- 340Vdc
+-<- +>------+ --- 4700uF
| \ / --- 200V
Neutral -----)---\/ |+
| --- 4700uF
| --- 200V
+------------------+--------- 0V
I also like to put bleeder resistors across each cap. Helps you not to get a
belt after the unit has been sitting around.
I was tought to always work with one hand behind my back!!
Try getting hold of some Workplace Health and Saftey videos before you
attempt anything. If they don't make you vomit, they will teach you to be
extremely careful.
