B
Bernhard Kuemel
Hi sed!
I want to build a basal body temperature thermometer which should
measure temperature in the 36-38C range to about 0,01C precision
(accuracy not needed). If I made a wheatstone bridge with the NTC in the
left leg and adjusted the right voltage divider with a potentiometer to
shift the voltage to the desired temperature, would the potentiometer be
stable enough? Or might it drift or change its value due to
thermomechanical motion? Then I would have to use fixed value resistors
instead which might require quite a few of them to get the needed
resistance value. Hmm, or maybe use few fixed value resistors and a low
value potentiometer in series (or a high value one in paralell) for fine
tuning.
The voltage range in the NTC leg is about 100mV across the 2C
temperature range, so 0.01C is about 0.5mV. Vs=5V, so 0.5mV is 1/10000
or 0.01%. What are the chances of a potentiometer changing by 0.01%?
What are reliable stabilities of potentiometers?
Thanks, Bernhard
tuning.
Thanks, Bernhard
